Here is my hz base model i picked up for a daily driver. i bourght it sight up seen for a good price but the project all most turned in to a bunch of spare parts when i found a badly rusted and bogged up rh gutter the length of the van. Also the RH quatter has been replaced from tail light to door and not fitted to well. After a few months off the project i decided to keep going and see what it looks like at the other end..
before.
GUTTER REPAIR FROM HELL!
I cant find the pics of the gutter before and when it was all cut out and a massive gaping hole from front to back. I cut the gutter off then cut the rust out. Then patched the hole. A mate of mine that is a sheet metal worker folded up a gutter that is fairly close to the original and then i welded that to the van. these pics a the repair with no filler.
The inside view of the gutter repair.
Disassembly
repaired and ech primed rear.
