Results 11 to 17 of 17
Thread: door handles
    Quote Originally Posted by Absinth View Post
    2pak is no problem as long as you use the correct mask, I have painted with it plenty of times in the garage without a problem.
    Is it just a respirator with correct filters or something more technical.
    Tis all I use..... chemical filters in a rubber respirator..... forgot to wear it once when doing a 2pak floor and had a huge asthma like attack, thank god one of the guys next door had a Ventolin inhaler..... thought I was going to cark it...
    Quote Originally Posted by 1BadVan View Post
    POR 15 is excellent stuff but is not UV stable it will go chalky matt black in about a month if left exposed to the sun. IMHO you can't go past two pac it's as tough as nails not like the origial paint used on the wiper arms acrylic lacquer. Just make sure you get a painter to do it as it is nasty stuff.
    Cheers Dave
    dont know what you have been using dave but the por15 i did my trailer in 2 years ago is still shining and it lives outside and doesnt get any love..
    Leadfoot 1BadVan's Avatar
    WA
    The primer POR 15 the super glossy stuff. In their product booklet it states not UV stable. I will ask the rep for some more info
    Do some research and please correct me if I am wrong in relation to masks suitable for 2pac. My understanding is the only respirator suitable for 2 pac is a positive feed respirator. In other words air is supplied to the mask/respirator via an extermal supply of filtered air.
    Cheers Dave
    and por15 is worse than 2 pack in regard to toxic smell and i suppose toxins...i use to paint chieftan canopies when 2k first came in and cob paints were all the craze in 2k..this was 23 years ago and i only used a normal mask...but back then the drugs i put in my body were worst than the paint fumes..sometimes im amazed im still here...back then i found holding my breath worked well....
    Cheers Dave
    Absolutely true Dave, Isocyanates are nasty odourless and colourless chemicals that are asthma inducing and cause respiratory problems with long term use and exposure.
    I was applying 2 pak to a floor with a lambswool pad and thought it would be Ok without a mask as I wasn't spraying it...... wrong..... the fumes were enough to give me a severe asthma attack.
    A dual cartridge chemical mask works fine for single applications during a short period.... I changed the cartridges after each use and used around four sets to paint a car.
    I also wore disposable overalls with gloves, booties and safety goggles, skin exposure is not good either and throw them away after each use.
    I was also in a shed on our 10 acre property and had a water filtered extraction fan venting out the door.....
    I sprayed 2 pak once in a suburban garage after emptying the garage of everything except the car and covered all the walls in plastic with a wet towel across the door into the house. Again I had a water filtered extraction fan venting out the back door.
    I will be painting my van this time around in the garage but this time I will use a Isocyanate free 2K system, not as good as true 2K but much better than normal acrylic and better for me, my family and the neighbours......
    If I was out on a property as wbute is and away from neighbours I would spray with normal 2K again... you do need to take the proper precautions though... don't have the wife or kids anywhere near while you are spraying....
    Just in case, I was only asking out of curiosity, not for advice from Absinth on how to apply 2 pac paint. I was really only asking because I forgot to ask if the gts wheel paint i have coming is 2 pac or not.
  1. Upper Tailgate Handles
    By Les in forum General Spare Parts
    Last Post: 08-09-2013, 12:01 PM
  2. Upper Tailgate Handles
    Last Post: 19-10-2012, 08:31 PM
  3. HJ sandman p/van door handles
    By locodriver2007 in forum HELP... Is This a Sandman?
    Last Post: 02-05-2012, 10:21 AM
  4. door handles wanted
    By greenhz in forum Archive
    Last Post: 23-09-2011, 01:33 PM
  5. Sandman door handles
    By wbute in forum The Lounge
    Last Post: 18-05-2010, 10:27 PM
