i have a blue 308 out of a WB statesman, it has an electronic ignition distributor.. what is the correct coil to use with it? will any oil filled one without the resistor work? what about the bosch hec/mec coils? thanks..
1975 HJ Sandman Van 308 trimatic.
1995 EF falcon XR6 wagon.
thanks for that, how is the voltage at the end of the yellow wire dropped to 9v? inline resistor somewhere or type of wire used?
It's what they call a "resistive" wire.
Never pulled one apart to find out how they did it though.
				It is a nichrome wire built into the harness. You need an original WB HEI coil, find on any VC-VL (not 6cyl VL). To get 12V to the coil just bridge the start and run wires prior to the ignition switch (go to coil as pink and yellow). This way there will always be 12V at the coil.
I did something like the above using the exsiting wiring to 12v system but ended up with voltage drop to about 10v thought the wire system whilst the motor was turning over and van was hard to start and would fire when I let the key off.I ended up putting a relay on 9v wire and run a supply 12v wire direct from the battery. startes alot better,but if bridging the wires work that would be realy easy. RB
