Results 11 to 15 of 15
Thread: white walls and white lettering
    Also try Tyrepower, that's who i got mine through.
    Mate,you can also try John Cain in Newcastle as he deals in them as well I will be getting my redlines through him.
    www.whitewalltyres.com
    TJ.
    Leadfoot 0488TINTER's Avatar
    Wetherill Park NSW
    just a note.
    If you get white walls done to tyres make sure you put 5000ks or so on them first to get a bit of the oil out of them first or the white will go brownish real quick
    nsw
    Quote Originally Posted by 0488TINTER View Post
    just a note.
    If you want to keep lettering or white walls white, clean the tyre with CT-18 and a pressure washer, then use prepsol on a cloth, wiping the wet spot carefully on the white so as not to smudge black onto it. then dissolve about 100g of white sugar in about 500 ml of hot water, and wash it into the sidewalls, drying with a clean cloth and your tyres will look schmick for any shows. I have been doing this on my Hog for ages, and it always works. Just keep the sugar solution and prepsol off your rims or you'll be polishing them again.
  1. palaris white hz van
    By Matthew Shaw in forum HZ Sandman
    Last Post: 27-01-2014, 04:02 AM
  2. HZ Sandman - white
    By phil in cairns in forum HELP... Is This a Sandman?
    Last Post: 31-03-2012, 05:21 PM
  3. White needle GTS Gauges.
    Last Post: 22-07-2010, 02:59 PM
  4. white stripes.
    By stickthis in forum HJ Sandman
    Last Post: 21-07-2010, 03:26 PM
  5. White Sandmans
    By stickthis in forum Decals by Stickthis
    Last Post: 20-07-2010, 07:51 PM
