Results 11 to 18 of 18
Thread: Injected 5l engine
    Northampton WA
    Yes that's what I did.
    Well I didn't weld it . It gives just enough room to fit the factory aircon brackets.
    cheers
    Quote Originally Posted by utevanwgn View Post
    cheers
    It is a bit hard to see in those pics what you did with the throttle body/manifold, would you mind talking us through it Nath if you get time?
    Dave.
    Northampton WA
    OK here goes.
    First cut off the flange where the throtelbody bolts on. Try and get it as square and flat as possible.
    I use a thin disk on a 125mm angle grinder. YES I know this is dangerous but if you spray the disk with liberal amounts of wd40 or similar and or use dry lube like candle wax it prevents the ally from building up on the disk and causing balance issues.
    Then place the manifold on the engine with all the accessories bolted on and GESTIMATE where the flange needs to be so when fitted it misses everything.
    Mark where it needs to be cut and cut it.
    If your not sure then remove small amounts at a time and sneak up on the final position gradually.
    Keep in mind that the mating surfaces need to be as close a match as possible so the welder does not have to fill holes and gaps.
    Finally I position the flange where I want it and drill and pin it into place .
    I do this so it can be trial fit before welding. And so the welder gets it in the right spot.
    Just one point If using steel pins make them easy to remove because welding ally with steel inclusions is not pretty.
    Degrease thoroughly.
    Then take it to your preferred fabricator.
    I usually clean it up with a die grinder (dipped in kero or wax to stop clogging ) and run a file across the flange to make sure it is flat.
    You will also have to cut a notch out of the ac bracket so the pcv valve fits.
    I hope this helps I would have explained earlier but I thought it was self explanatory .
    Click Here
    Popped the link here. Cheers Nath for that!
    Ahhh, now I see! Thanks for that!
    Leadfoot JDT's Avatar
    Apr 2012
    You could do what I did and remove the injection set up. I used a dual plane Torque Power manifold and a 750 square bore double pumper Ultra HP Holley. Incredible performance gain. Up to S%$T fuel economy but who cares.
    Apr 2012
    I haven't quite finished under the bonnet yet. Can't decide on a set of tappet covers.
    Northampton WA
    The whole point was to keep the efi and do it cost effective.
    The whole conversion including new tail shaft motor trans electrics and radiator cost less than $1500 .
    I could have kept the original 253 if I wanted a carby
  1. Holden 5.0 injected motor
    By hqhzvans in forum Engine
    Last Post: 14-03-2014, 09:54 PM
  2. HQ Panel Van Injected 5l - eBay - Vic
    By Alien DNA in forum Vehicles or Items Found for Sale
    Last Post: 28-05-2013, 09:06 PM
  3. WTB Injected HZ Tonner
    By darknstormy in forum Archive
    Last Post: 20-03-2011, 07:59 PM
  4. wb caprice 5 ltr injected 1 tonner
    By ozbox in forum Archive
    Last Post: 30-11-2010, 12:02 PM
  5. looking for an injected 5L
    By Epic_Dragon in forum Archive
    Last Post: 24-09-2010, 08:07 AM
