Results 11 to 16 of 16
Thread: Engine to Chassis mating time.
    If i had to do it, i'd do the chassis first then do body leter.
    It'd would make the process of engine/trans assembly much easier and be easier to fit stuff.
    Imagine if you damaged the firewall with the gearbox/engine assembly or damaged the paint with the engine hoist.
    Just my 2c worth anyway.
    Engines would have been on the subframe/chassis and the body fitted. That is how i'd do it, but Blocker if I were you i'd invest in a 2 pole hoist. A secondhand Molnar is about $2200 installed and certified.
    Id put the engine and trans on the chassis, then lower the body on. That said, with a bunch of mates helping you out, it could be done a hell of a lot easier and safer than trying to do it solo.....all those extra sets of eyes guiding the body on will be invaluable. Best of luck mate
    ive done a few as you would know..have the complete chassis with everything in it done..brake lines fuel lines tank etc etc etc....then drop the body over..there is pelnty of room and you should not scratch any paint...do not bolt the body down before aligning the front panels...once all front panels are aligned and you have the body sitting square on thye chassis then bolt it all down...make sure you use a rattle gun coz they are supposed to be pulled down very tight on the chassis rubbers..
    Thanks mate! This will make my planning easier now that I know what stages the chassis, body and running gear gets prioritized.
    blocker look at the sinbox build in my shed and you will see how we did the removal of the ute body and replacement..even though it wasnt a full blown resto it will give you an idea...
  1. HX Ute Chassis - Victoria & HJ PV Chassis - Sydney.
    By ABSINTH74HQ in forum My Items For Sale or Buy
    Last Post: 23-09-2013, 05:09 PM
  2. Once upon a time....
    By sandman77hx in forum The Lounge
    Last Post: 14-09-2012, 03:57 PM
  3. Decision time...
    By Dago in forum The Lounge
    Last Post: 23-07-2011, 11:13 PM
  4. Time for some nostalgia!
    By Rodger Kelly in forum HZ Sandman
    Last Post: 18-01-2011, 09:58 PM
