Results 11 to 20 of 20
Thread: disc brake rear end or not?
    I think you have to change it to a 4 wheel disc master i had to in my hz van
    Are you sure you dont have to change the master cylinder
    Quote Originally Posted by Glacier 73 View Post
    yep you do. or put a reducing pressure valve in the flare of the rear brake line of the master cyclinder
    No you don't have to replace it. Just remove the little brass check valve in the rear outlet. Takes less than a minute.
    Yep, waste of time. When you hit the anchors hard in these things all the weight transfers over the front wheels and the rear brakes do about as much work as a federal politician. If you're going to spend money on brakes then upgrade your fronts instead. Rear Disc Brakes look good in a For Sale ad but won't be much benefit in a van.
    P Plater Sndman77's Avatar
    Rockhampton, QLD
    Are you sure about this being a waste of time, disc brake on the rear. My hx panel van had disc brake (wb disc brake diff) fitted on way before I purchase the van. To be honest, best set of brake, good braking control and pull up very quickly. Better brakes than my hz ute (which has rear drums) and also the LE coupe I own (rear drum brake also). HZ GTS I have also (rear disc brake - which was standard), very good braking and control. Personally, I would think the panel van would have enough weigh over or at the rear end and wind factor (van are not the most aerodynamic cars) that rear disc brake would work very well. Let say, fitting rear disc brake to a ute, lite in the rear end and more aerodynamic, the weigh transfer you are talking about, I can understand and agree that rear disc brake could be a waste of time. All I can say personally, disc brake work very well on my panel van and I have decided to leave them on.
    Don't Come Knocking If This Van's Rocking
    Thats why i got rid of my disc brake rear end for that reason it would take to long to pull up
    Drums on the back are still current on a new hilux, so why go to the drama of fitting them to a hq-wb commercial? Agree that upgrading front brakes would money better spent.
    my tow vehicle is a WB stato, and the 4 wheel disks help alot when towing car trailers - gives me alot more confidence approaching roundabouts etc.
    Drums are actually better at braking than discs...but only for a few high speed stops until they get hot, then they lose efficency. That is where discs excell, at repeated high stops, disapate heat better. So unless you're doing track work I'd stick with drums at the rear.
  1. VN Disc brakes fitted to 10 bolt diff
    By James in forum Driveline
    Last Post: 01-06-2015, 08:20 PM
  2. brake upgrade
    By utevanwgn in forum Brakes, Wheels & Tyres
    Last Post: 03-07-2014, 08:03 PM
  3. Brake calliper replacement for rear end.
    By Maysik in forum Brakes, Wheels & Tyres
    Last Post: 22-05-2014, 02:08 PM
  4. Brake Proportioning Value
    By hj308 in forum Brakes, Wheels & Tyres
    Last Post: 18-06-2012, 08:27 PM
  5. HZ commercial vehicle disc brake rears
    By mauser in forum Driveline
    Last Post: 17-06-2012, 10:04 PM
