Results 1 to 5 of 5
Thread: HX sandman front suspension height ........ help ?
    Apr 2012
    Can anyone please tell me the standard height from the ground to the centre ofn the wheel arch on a HX V8 sandman ?
    P Plater Davestown's Avatar
    Castlemaine
    Peter,
    I measured my HX and it is 66.5cm from flat ground to middle of wheel arch on the front, I have owned van
    Ute or van? Might be a difference!!!
    Apr 2012
    Quote Originally Posted by Gaddy View Post
    it is a van both front and rear wheel arch standard heights if able
    Its not listed in the owners manual, only ground clearance and overall height. You could work it out from those measurements I suppose.1608mm and 173mm ground clearance. Actually the total height will tell you what you need to know.
  1. Front suspension rebuild
    By Blocker in forum Chassis
    Last Post: 24-04-2018, 09:15 PM
  2. Front suspension swing arm bolt torque settings
    By Harry in forum Steering & Suspension
    Last Post: 27-03-2015, 07:53 AM
  3. statesmen front v sandman front
    By Matts HX in forum The Lounge
    Last Post: 27-05-2013, 08:52 PM
  4. Hz ride height
    By luke in forum Steering & Suspension
    Last Post: 15-07-2012, 10:58 AM
  5. Radial tuned suspension badge
    By RodneyHZ253 in forum Steering & Suspension
    Last Post: 27-08-2010, 12:10 AM
