Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
Thread: Another Adjusting Problem on my WB!!!
  1. #21
    if it has an aftermarket clutch kit in it the thrust bearing is probably smaller than the original,thats why it has the clamp there but the correct way to fix it is adjust the ball that the fork pivots on . the thrust bearing doesnt need to be much shorter to cause problems because your clutch works on a leverage system .i have had this problem twice and have fixed it by adjusting the ball that the fork pivots on . it only takes 1-2 mm adjustment
  2. #22
    Northern NSW
    Quote Originally Posted by thatotherguy View Post
    I have no idea what clutch has been put in it.. I've never had the gearbox separated from the motor either.. lol I'll give her a go and hopefully it doesn't take too much to fix it..
    Cheers,
    Matt
    My WB Ute Build:
    WHERE ARE YOU BHZ29069A!?!?!?
  3. #23
    the carrier and bearing on the left is for a push clutch..every all synchro 3 and 4 speed v8 or 6 to early hz...the middle carrier and bearing is for pull clutch..late hz wb and vb vc vh vk commodore 6 cylinder...the carrier and bearing on the right is for pull clutch in v8 for late hz wb and vb vc vh vk vl vn vp vr and early vs with t5 but not late vs getrag gearbox as they are hydraulic..you should be able to see the carrier and bearing through the inspection cover...another clutch adjustment problem in v8s is the incorrect supply and use of the 6 cylinder carrier and bearing...note the hieght differences..hope this helps figure out yours and everyone else who may have this same problem....just a note,most places will tell you the v8 carrier for anything up to vl is obselete..fact is they superseded the part number when they started using the carrier with the t5 boxes in vn on..so if you get that answer ask for one to suit vn v8 or ring me coz i have them in stock new..
    Quote Originally Posted by 83 WB_Ute View Post
    I am looking for one of those clutch for covers, I don't know where mine went and I need one of those cause you definately don't want water and shit getting in there!! lol
    most cars are missing that cover..i have a couple here..
  4. #24
    Northern NSW
    Thanks OZ, that makes it much easier to understand what I am looking for.. Cool, how much are you asking for the covers???
    Cheers,
    Matt
    My WB Ute Build:
  5. #25
    $25 for the cover..you would think with the thousands of late hz and wb and commodore manual cars ive wrecked over the 20 years that ive been here i would have a box full of them....i have 4...
  6. #26
    Northern NSW
    So is that $25 posted?? and what sort of condition is it?? Also, what are your direct bank deposit details??
    Cheers,
    Matt
    My WB Ute Build:
  7. #27
    no its $25 for the part plus postage which is registered...postage is $15..condition is good..so $40 delivered.
  8. #28
    Northern NSW
    Cool, I'll give you a ring sometime and get your bank details off you..
    Cheers,
    Matt
    My WB Ute Build:
  9. #29
    Northern NSW
    Well the gearbox is out now.. I had a small go at adjusting the clutch fork and got it much better than it was before.. I will have a better go tomorrow, and hopefully make it perfect and get it all fixed!!
    I also took the oportunity to clean the 30+yrs of grease and grime off the gearbox while it was out. I also found it has a very bad rear seal leak. It is leaking out the new oil that was put in 3-4months ago..
    Then on monday it is off to see the blue slip guy to confirm what he wants done if I put the 4spd in...
    I'll let you know how it goes!!
    Cheers,
    Matt
    My WB Ute Build:
  10. #30
    Northern NSW
    Well, going by the above picture and description I think the throw-out bearing in my ute is the wrong one :(
    Here are some pics.
    And just a few more showing the 30+yrs of grease and grime on the gearbox and the cross member.. lol
    What do you think??? I think the one in mine looks like a push type one... When I should have the middle one.
    This is probably why it is out of alignment and causeing me greif!! :(
    Cheers,
    Matt
    My WB Ute Build:
There are currently 10 users browsing this thread. (0 members and 10 guests)
  1. HZ GTS dash clock adjusting knob and screw
    By Monman71 in forum Interior
    Last Post: 23-12-2014, 12:49 AM
  2. typing problem
    By HJRAY in forum The Lounge
    Last Post: 07-06-2013, 01:24 AM
  3. M20-M21 Selecting 1st problem
    By Calum in forum Driveline
    Last Post: 08-05-2013, 09:52 PM
  4. 308 Lifter Problem
    By chrisp in forum Engine
    Last Post: 22-03-2013, 12:13 AM
  5. Adjusting WB Door Windows..
    By 83 WB_Ute in forum Paint & Panel
    Last Post: 05-07-2012, 09:45 PM
