Thread: Front Wheel Stud keeps rotating
    P Plater Cyclamin's Avatar
    May 2012
    Dunsborough WA
    Hi,
    Front GTS rim had a bit of a rattle so i decided to take the wheel off to have a look and one of the studs has started to rotate with the Nut still on.
    How the hell do you get it off with the stud spinning??
    Never had it off prior??
    Any ideas??
    Rob
    Try a rattle gun.
    maybe put a bit of weigh on the tyre iron, so hopfully bite in and you can crack the nut and undo it with you fingers, or tack the stud the back of the hub?
    Not easy, you migt have to get them all off bar that one and lever the wheel against the nut to pull the stud in tight. I'd replace the disc afterwards.
  1. Changing Stud Pattern
    By hqhzvans in forum The Lounge
    Last Post: 26-09-2014, 08:48 PM
  2. Hx front wheel bearings
    By don3527 in forum The Lounge
    Last Post: 28-03-2014, 08:56 AM
  3. Magnum Mag needed. 14 x 7" HQ-WB stud pattern.
    By Big Rob in forum Brakes, Wheels & Tyres
    Last Post: 24-02-2014, 05:59 PM
  4. Replies: 7
    Last Post: 22-01-2014, 10:54 PM
  5. Wanted - front wheel tubs suit HJ
    By GTS in forum Archive
    Last Post: 11-01-2011, 02:27 PM
