The replacement tank all cleaned up and ready for painting. Im painting it in a matt Urethane. I wanted a few contrasts rather than the one finish. So the straps are done in a semi gloss, the underside also in a semi gloss and the chassis will be a full gloss.
Chevrolet Avalanche
HQ Wagon
Diff clean up time
Chevrolet Avalanche
HQ Wagon
The under side is all done in KBS semi gloss RustSeal
The inside of the rear guards have been done in body deadner
Chassis will need a good wipe down before final assembly
Chevrolet Avalanche
HQ Wagon
Can you please slow down a bit your making all of us look bad with the speed you work in
but seriously your doing a bloody great job grunt hope i can work as fast as that when its my turn
keep up the top work mate
cheers gene.
The chassis has been painted from the back to just past the firewall area. The Chassis will need a good wipe down before final assembly
Painted the tail shaft red for a bit of a contrast
Chevrolet Avalanche
HQ Wagon
Got the diff in, springs cleaned up, new spring bushes, shock, rear brake hose and 2 way fitting. Of course the brake lines had the wrong fittings so I had to re flare the brake lines to fit the 2 way distribution connector. The brake ines were sanded back to make them all shiny and new. New drums, shoes and wheel cylinders were fitted and again the fitting were wrong for the bake line to wheel cylinder connection so some more double flaring was called for. The tank was installed, wish I had detailed pics of the bracket setup before I pulled it apart. Im sure the guy who designed the Rubiks cube designed these brackets.
I have to sand back the hand brake outer and clear coat these to bring them up to spec
Chevrolet Avalanche
HQ Wagon
The upper section of the firewall has been stripped back and sprayed semi gloss black
Chevrolet Avalanche
HQ Wagon
Looking awesome mate.
Do u work at the moment aswell because the way you are going it looks like you dont sleep zzzzzzzzzzzz.
There are currently 11 users browsing this thread. (0 members and 11 guests)
