Results 21 to 30 of 36
Thread: HELP! Starting Problems with Blue 253
    I am totally at my wits end with this POS!
    It starts intermittently on the key. Starts and runs when you push start her.
    Ive
    Replaced battery earth
    swapped starter motor
    replaced plugs
    replaced dizzy cap and rotor button
    its strange. it will start on the key and then you switch it off and it wont start again and other times you can turn it off and on as many times as you like. HK has suggested ignition switch which will be my next stop but i'm wondering if there are any other suggestions. i don;t like the idea of dropping the column and messing with wires. i seem to bump or break wires pretty easy. A mate reckons that coz its a old clunka that the lifters are likely to be sticky and its not getting enough compression to fire. Lift the oil filler and its a bloody dirty sludge fest in there :(
    some suggestions would be warmly welcomed
  1. WB fuel problems
    By xale in forum Engine
    Last Post: 02-04-2014, 01:06 PM
  2. HZ DX5 Sandman Stripes! DONE!!!!! Light Blue, Med Blue, Dark Blue.
    By stickthis in forum Decals by Stickthis
    Last Post: 23-09-2013, 11:22 PM
  3. WB Blue 202 Problems... Help!!!
    By 83 WB_Ute in forum Engine
    Last Post: 07-04-2013, 02:12 AM
  4. Starting Point
    By Dago in forum HX Sandman
    Last Post: 23-06-2011, 12:39 AM
