Results 11 to 20 of 24
Thread: Late Model Blocks
    Don't use those spacers. Awful damn things. $275 in Sydney to redrill a block is a much better option.
    So true, - you could also have a look at what Castlemaine Rod Shop has on offer, that might give you a heap of options to consider.
    The bell-housing I got from them (308 Chevy pattern to Holden) is everything I expected, or better, great cast finish and nicely machined. It was just as affordable as any other option, delivered quickly via Aust Post, and came with a neat "CRS" logo embossed in the side of the casting too.
    Worth a look on their website, probably a phone call too!
    Yeah, I've used the spacers and they are a bit messy since everything has to be spaced the same amount. If the motor is going to be out of the car it's a no-brainer to get it re-drilled and dowelled. If you wanted to change the 'box without pulling the motor, then a spacer kit is the go.
    VB, VC, VH, VK. Could be any. Only the engine number will give up which one. Unless it is something like VT1020 it will be a long valley bolt boss block.
    How much$$$ are the crs bellhousings these days ?
    i recentley sold a crs turbo to aussie pattern with fork for 100 bucks just to get rid off it who wants to put aussie 4 sp behind a semi worked 308 or a chev
    Victoria
    I do, I do! I love changing gears. Seems everyone wants an auto these days.
    Not that there is anything wrong with an auto, but I'd prefer to change gears!
    Leadfoot rallyvan's Avatar
    Western Sydney
    A couple of other questions for those that have repowered their van or ute with a latter model motor and gearbox. As my van was equipped with a Trimatic do I have to change the gearbox cross member?
    4L60 just about fits a TH350 crossmember. If you can find an early WB Statesman crossmember you can shorten it or modify the M15/20/21/22/40 one to suit.
    Jan 2013
    Nth nsw
    Just wondering how we go with rego using late block I know date codes might line up 94 and 74 wise but won't the vr type number flash up in database then have to use all late pollution gear? And what is the actual difference with the turbo gbox crossmember are the holes further back or does the box have to sit lower have a crs type for the t700 but doesn't look very original though
    Quote Originally Posted by Cocko750 View Post
    Then don't tell anyone you've changed it! How often do engine numbers get checked? If it does eventually get checked, tell them you just put it in and haven't got around to changing the number yet.
    Or there are "other" ways......
  1. Links in signature blocks
    By Blocker in forum Forum Announcements & Suggestions
    Last Post: 11-05-2014, 05:39 PM
  2. Damn big blocks
    Last Post: 13-02-2013, 07:37 AM
  3. On blocks- advice?
    By Vombil in forum The Lounge
    Last Post: 05-05-2011, 11:34 PM
  4. Lowering blocks
    By hainzy in forum The Lounge
    Last Post: 22-03-2011, 08:24 PM
