Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Brake Sender Unit
    Jan 2011
    Toowoomba
    Brake Sender Unit
    All I am trying to sort out my wiring on my ute but have found a problem. I have a single point relay on the brake sender unit but the wiring is for a 2 point. What should a HX have?
    Thanks Jim
    Hi Jim, I'm not sure I understand this question.
    I think you are describing the electrical connection on the "t piece connector" (by "t piece connector" I mean the piston housing for the dual brake system - which distributes the brake fluid to front and rear brakes, and bolts on to a bracket over the drivers side shock absorber tower)?
    It's known as a proportioning valve.
    Brake Fail Warning Switch.
    A much more accurate name yep, but it often slips my mind, 't peice connector' was used by Gregory's in their LH-LX manual.
    I can only find a single wire in the wiring diagrams for HQ-Z but I know the two wire version exists. It has a plastic cap with lock.
    Not sure when the change happened.
    Yep it's a good question. Has stumped me in the past. Just did some quick web research (haven't got any books at all with me atm).
    These links may help for starters.
    http://holdenpaedia.oldholden.com/Br...rtioning_Valve - (need to scroll down to bottom of page to see all three entries)
    http://www.aussiev8.com.au/members-l...ing-valve.html - (look especially at post #4, it also conflicts with psi numbers on post #1)
    But, this is only brief web research, and isn't conclusive, the aussie8forum post #4 lists four valves, and the holdenapeadia site entry only comes up with three, also neither focus on vans. (I realise you have a ute Jim).
    For the brakes to work as designed you obviously need the right proportioning valve for your set up, however (and I have wondered this before), many H series in existence today may have had the valve replaced with a spare from a wreckers by a previous owner at any time, and that could have come off Torana or any 70s H series - which may be the issue you face Jim, - (unless, as an alternative, the wiring harness could have been changed/adapted)?
    About a decade ago I got handed a "clean" proportioning valve for my HJ wagon from a wrecker who pulled it off a car with good lines for me, but I never knew what it came off! (it passed the brake test at rego so lol.... well, lol with a 'hmmmn um' , attached.)
    Knowing what models of proportioning valve were used, and which one for which type of vehicle and brake set up has always been beyond me - I never knew where to get the information. Does anyone happen to know off-hand? Otherwise, maybe this could be a good research thread.
    An affirmed and accurate list, (model nos, crack points, vehicle series and brake options) would be a really useful thing.
    It was an ADR change to the 2 x wire switch. which separated the brake fail indication from the handbrake indication. Changed in HX or late HJ from memory.
    Jan 2011
    Toowoomba
    Thanks everyone for the information. I will start looking for one today
    Must have been HX. HX gts dash has brake fail and hand brake warning lights, HJ shares a light and had high beam warning in the other spot.
    Eastwood, NSW
    AFAIK they used a single pin differential pressure switch for late HG, all HQ & HJ. HX saw the 2 pin switch & this carried thru to HZ & WB.
    On the late HG & HQ the switch was mounted in a junction block. There was no proportioning valve on HGs & on HQs the prop valve was mounted along the subframe rail under the driver's seat, on disc braked cars only.
    For HJ, HX & HZ the switch was mounted on the proportioning valve. In WB it was mounted on the master cyl which also had the proportioning valve in built.
    Dr Terry
  1. VDO oil pressure sender
    By panoz78 in forum Electrical
    Last Post: 28-02-2017, 08:25 AM
  2. HQ ute bookshelf/wall unit/tv stand!!!
    Last Post: 25-05-2014, 06:56 PM
  3. Hx fuel sender into 8/74 hq
    By Vombil in forum Engine
    Last Post: 28-02-2013, 02:21 AM
  4. oil gauge sender
    Last Post: 10-08-2012, 11:31 PM
  5. Turbo 400 speed sender unit
    By HX76King in forum Driveline
    Last Post: 27-04-2012, 11:35 PM
