Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Need help identifying HQ plates
  1. #21
    B. B is used for buckets, A for bench. There isn't a "short" console, it is a seat separator, and it was mandatory with buckets except with 4spd or if console shift was standard. The only places in a HQ Belmont or Kingswood where console shift was standard were as a result of a special vehicle package being applied to that Belmont or Kingsowod model:
    SS (V8 Belmont sedan).
    GTS (V8 Kingswood sedan).
    Sandman (6cyl or V8 Belmont ute or van, or 6cyl or V8 Kingswood ute).
  2. #22
    May 2014
    Fits beautifully with the rest of the numbers, so eitehr a mistake in seating capacity (should be 3 not 2) or it is a mistake in trim code (should be 39B instead of 39A).
    The way to know which is wrong is to look at the back of the tunnel for a little pressed steel bracket, basically between the (bucket) seats but to the rear. If that is there is is a bucket seat car as a seat separator was mandatory with buckets on that car. If it isn't it was a bench seat car.
    Is the pressed steel bracket on the inside of the car or under near the tunnel??
  3. #23
    It is to mount a seat separator or console so it is inside, between where buckets would be on the top of the tunnel at the rear.
  4. #24
    May 2014
    It's the wrong trim code then as it has the console bracket there.
  5. #25
    Cool, it means it is a bucket seat car with seat separator and column shift.
  1. Help identifying monaro
    By hdt134 in forum The Lounge
    Last Post: 13-08-2014, 03:58 PM
  2. Identifying an engine
    By matt.p in forum Holden Sandman Q&A
    Last Post: 10-12-2013, 08:34 AM
  3. Help with identifying this van please.
    By sundowner in forum HELP... Is This a Sandman?
    Last Post: 27-12-2012, 01:54 PM
  4. Identifying a HQ Vactioner
    By 79Z33L in forum The Lounge
    Last Post: 02-09-2012, 07:33 AM
  5. scuff plates/kick plates
    By green taxi in forum HJ Sandman
    Last Post: 14-09-2011, 07:14 AM
