Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 48
Thread: Seriously BIG car audio visual systems!
    Nov 2012
    Busselton
    Quote Originally Posted by damienengland View Post
    Frosty, that's gold! A smoke machine sounds awesome to me. Maybe a bit cheesy to others but i love it. How do you find the Dynamat?
    I found the Dynamat did a great job of cutting the road noise and the drumming. Not sure the difference to the sound as I put in the Dynamat in before the noise system but it does sound very good. I also found the Dynamat expensive, about $500 to do the rear of the van. Smoke machine is amusing and very cheesy
    Dave, awesome post. Like others, i took all day to get through this but you're bang on. I haven't studies sound engineering but have spent many years installing audio, including car stereo (Morley Hi-Fi and Micro Electronics), home theatre (electrical contractor with a West Coast Hi-Fi contract) and finally commercial sound systems in bars and clubs etc.
    The keys to power are exactly as you said and i have always been told to work our the needs of a venue then double it so the amp racks are essentially idling when in use. A couple of notes i would add include checking out the given Total Harmonic Distortion (THD) specification vs RMS power and also remember the power supply is critical to the peak performance requirements we are seeking.
    Have a look at the specs on this Alpine Mono Block amp as an example-
    Specifications
    CEA-2006 Power Rating (40hm @ 14.4V = 1%THD+N), S/N 80dBA (Ref. 1W into 4Ohm): 1000W x 1
    RMS Power (at 14.4V THD+N,20Hz-200Hz)
    Per channel into 2 ohms : 1000W x 1 (<=1%THD+N)
    Per channel into 4 ohms : 1000W x 1 (<=1%THD+N)
    Dimensions
    Heat Sink (WxHxD) in: 10-1/8" x 7-9/16" x 2-7/16"
    Heat Sink (WxHxD) mm: 257mm x 192mm x 62mm
    Bass Engine®
    Crossover Frequency : 50Hz-200Hz, -24dB oct (LP)
    General
    Input Sensitivity (For Rated Power): 0.1 V to 8.0V
    Input Impedance: 10k Ohm
    Power Requirements: 14.4V DC (11V to 16V)
    Speaker Impedance: 4 or 2 ohm
    Frequency Response: 20Hz-200Hz (20Hz/-3dB)
    Signal to Noise (S/N): 110dBA (Reference to Rated Power)
    - See more at: http://www.alpine.com.au/showItem.ph....HZlb9G1U.dpuf
    A couple of the keys here are that the RMS rating is given for a consistent 14.4VDC supply with a 1% THD (plus noise) and the frequency response is only quoted at 200hZ maximum so i take it there is some fudge factor in this amps performance. Even so, i bet this amp does very well connected to a sub woofer!
    Leadfoot 78 sin bin's Avatar
    Apr 2011
    Port Lincoln Sth Oz
    Quote Originally Posted by Frosty View Post
    I don't know much about this stuff but I put a modern stereo in my van. It has 1100w mono amp behind passager seat. 2 8inch subs just behind the archway. 2 6x10 3 ways at the back. 2 x 3 way 5 inch in the kick panels. (old panels were out of a WB ute and already stuffed )Head unit is Sony, CD,blue tooth, USB with adjustable sub volume. I also put acoustic sound stuff (Dynamat ?) right thru the rear. 10 inch tablet goes on the arch and plugs into the system for movies and music. It's also has under car LED lights in the back and a 2 kw inverter that runs a smoke machine. Gps tracker unit in hidden in the car incase somebody feels they want to take it away.We don't drive fast but we do listen to very loud music and smoke it up sometimes.
    hey frosty have you got any pics of your tablet setup? I want to do something similar myself. something I can remove for everyday driving and mount wen needed..... could you give me more information as to how you get it to sync with your headunit as well please? I am totally audio visual dumb...cheers mate
    EVEN THE YOUNG GIRLS LOVE SANDMANS!
    Nice novel Dave!
    Normally if I want to read something that long I buy a book.
    Good info though, if a little eye glazing for a forum.
    Point gracefully accepted, however, perhaps spare a thought for me, (I entered the entire post without using an "a" key - I spilled beer in the keyboard). so, I was actually tryna save words (I had to cut and pste each "a" - and still am!)
    Awesome post Dave. That would go a long way to explaining why the "150 Watt" 3way 6x9 Blaupunkt (spl?) speakers I put in the doors of my ute 10 years ago still seriously outperform the supposedly "bigger and better" ones I recently put in my daily commuter wagon, even though they are mounted correctly and have a similar sized void behind them. Both are just driven directly from the head unit and both head units are rated at the same output/channel.
    Cheers.
    Great example. For a premier manufacturer producing some of the best car audio this doesn’t make heaps of sense, when really it could be made very clear. And all manufacturers are doing it of course, the market requires it.
    The specs you have quoted from this manufacturer are for one of their top notch, high performance single channel subwoofer amplifiers (some other manufacturers are calling these “monoblock” amplifiers).
    Its actually designed to power a subwoofer only. (This is why the very limited 20Hz-200Hz) frequency range. Its mono, and will not be able to reproduce frequencies higher than 200hz with much volume or accuracy at all. This is because it is not intended too, its job is all in the sub frequency range. As you say, its most likely it would perform really decently in those ranges. (although for $800 just to power a subwoofer it would want to)!!
    I noticed manufacturers using 14.4V as a standard quoted supply voltage a few years back, that seems fair enough to me actually, (they have to use something, and most cars will have around 14.5 avail when running) but yes I agree it may also allow them to tweek the final output specification upward depending on how they’re measuring it, but, theres other stuff in there too that is fairly meaningless.
    For instance, it seems to be claiming 1000W RMS (including noise as you point out) going into 2 ohms, and also 1000W RMS (including noise) going into 4 ohms, (ok, assuming that its feasible that the electronics can do this at either 2 or 4 ohms... ), where is the explanation of exactly what it means. What are they actually saying? It’s a fairly important spec for sales.
    Remembering that its only producing a very small amount of the audible frequency range (20-200Hz) and that it seems to have a “crossover” (probably a High Pass Filter – adjustable you’d hope at that price) that can operate at around 50Hz – again it doesn’t say if its fixed, or goes up, or down from 50Hz , which will further limit this very narrow frequency range, so, what frequencies will it actually be able to produce to provide its optimum “1000W RMS”?
    …..1000 Watts of what exactly?.
    If you think about it, its producing such a limited frequency range, that its performance is going to be closer to a version of Peak Music Power (perhaps continuous, and before distortion), but I don’t know if that (if thats what it is) should really be called 1000W RMS - but theres no way of knowing reading the specs, what is actually being described.
    Now because its only a mono (one channel) amp, and the range is so low, and giving the manufacturer the benefit of the doubt lets assume it is able to produce, from an amplifier that size, some form of continuous bass frequency operating at 1000W. Lets imagine the current drain.
    Power (Watts) = Volts (V) x Amps (A).
    W/V = A
    1000 / 14.4 = 69.4
    Close enough to 70 Amps!
    So , for the amplifier to produce the claimed 1000W of power, it would need to be able to draw 70 Amps or thereabouts continuous current draw from the battery or the charging system. .
    The draw on the charging system would be unsustainable very quickly. And on top of that, you still need another amplifier around the same size to run the front channels. (so say 120 Amp current draw for both).
    Now I’m not saying that this doesn’t happen, it can happen quite easily, a big amplifier and Sub set up installed improperly is easily likely to threaten a cars charging system, and, can (for instance) cause fires, stop the headlights, or windscreen wipers from working properly, etc it happens! Installation is a serious issue with big amps in cars, extra batteries, beefed up alternators, even an extra alternator in some cases may be needed or justified.
    It is quite possible to achieve 1000W RMS in a car, (if one really wants it) but, it makes me think twice about whether a big brand would sell an amplifier that big on the net, it needs professional installation so in the back of my head I wonder, perhaps another discrepancy there.
    So yep a good example. (And all the manufacturers are doing it). All that said however, I reckon, reading carefully, (guessing between the lines basically) specs like these can actually give you a vague idea of the capability of the unit in question because, you can judge how far the manufacturer is prepared to be caught out lying blatantly – some lower quality brands may not care, the better ones will care more, whilst these specification descriptions may not be at all clear, for the higher end manufacturers the gear still has to sound like it meets what those specifications may seem to claim, so with care you can still make a fairly informed choice.
    This doesn't mean that the specifications given above can't be believed, its just that its not easily clear to see exactly what they are specifying.
    They are after all a top brand, if you have their components and they are set up correctly its pretty hard to go wrong. This is perhaps why its a good example, they make great gear, you'd have to imagine its an excellent piece of equipment, but even their specs aren't clear about the RMS rating.
    So coming to terms with the issue of volume and “Watts”/ "Watts RMS" not necessarily being what they say they are (and most often, many many miles apart) is really important in selecting car (or any) audio system. A more important specification for all amps, head units, and speakers is the Frequency Response figure, (distinct from frequency range) from this you can get an idea of overall sound quality produced by a component (as opposed to volume) but this is turning into another essay atm so maybe more a little later.
    Nov 2012
    Busselton
    Quote Originally Posted by 78 sin bin View Post
    Photos continue to elude me as does many things. I used stick on Velcro and Blue tooth connected to the head unit. mine is on the arch way. Pick a unit with Blue tooth, works for your phone as well.
    Victoria
    Quote Originally Posted by Indy Orange View Post
    So where do you hide them then Dago ,without mutilating front kick panels or front doors?
    Looking around in the ute, I think the subs could easily be mounted behinds the seats, along with an amp, though size is a problem. Unfortunately, the only place for speakers would be to mount them in pods on the doors. Externally so you didn't cut the steel. The splits could be mounted into the holes above the upper seat belt mounting points.
    I haven't got that far yet, but that was my plan. I have holes in my doors so I currently run 6x9's behind the seats and 6 inch in the doors. No amp.
    Quote Originally Posted by SLR_dave View Post
    W/V = A
    1000 / 14.4 = 69.4
    Dave, another great thesis and its awesome to see Ohms law getting a workout on MySandman. With reagrds to the current draw, i have seen this in action. I had a Sony X-Plod (1000W RMS branded) amp running two Alpine 12 inch subs some years ago and suffered several failed alternators in my VT 5lt common door. I connected an amp meter to the alternator wire and measured a max draw of 120A with everything on such as headlights, A/C, sound system up full etc etc. Its an area not many people think about.
    Very informative thread...top stuff guys
    Now...can anyone recommend me some speakers that are able to handle metal music? I'm being brick walled every time i go to a car audio store and ask the same question. Usually met with a blank look or a stuttering response which indicates they have no freaking idea. A friend has an audi that has factory stock Bose speakers that sound great at mid volume levels, but farts out when the volume is cranked. At low and mid volume level its sounds great, but metal isnt meant to be listened to at acceptable levels.
    Any help would be great
  1. Modern EFI systems
    Last Post: 21-04-2014, 02:49 PM
  2. Holden - Systems for refinishing used cars
    Last Post: 21-04-2013, 10:28 PM
  3. Wiring sound systems!
    By 83 WB_Ute in forum Electrical
    Last Post: 29-01-2013, 07:15 PM
  4. LPG Systems
    By rallyvan in forum The Lounge
    Last Post: 13-01-2011, 07:01 PM
