Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: Saginaw 4speed shifter??
    My Saginaw box is behind a worked 202 triple carbed GTR torana running a 3.55 lsd diff
    the gears on the box are fantastic with my engine really short shift
    and great gear ratios regularly touch 7/ 7400 rpm so far so good
    tuff enough for me
    You'll struggle to get the Saginaw and Hurst to fit without a tunnel mod for the shifter. You need a modified stick in either case to gst it back to the tunnel hole.
    No problem in a light bodied car. A blown V8 Panelvan with big rubber = good luck!
    Air saw is your friend
    Cruiser RAEME's Avatar
    Thank you for the above information guys appreciate it lots. So um anybody want to buy a Saginaw gearbox?
    Quote Originally Posted by RAEME View Post
    Pm me a price
    cheers
    Have you got a picture of it and what comes with it?
    Hi guys, was in Sydney on course, picked up the gearbox yesterday. I have been thinking about pulling the Blown engine out and putting in a stroker 308. I'll play with the box bit first. If I decide to move it on I'll let you know. It came with new heavy duty clutch, speedo cable, Dellow bell housing, rear mount and cross member and a plastic inspection cover. Also with complete hurst shifter and linkages. I'll have a play with photobucket later and see if I can load some. Cheers
    Seeing if the photo attached of the Saginaw kit I bought.
    Looks liks a Speco bracket for the shifter. Bellhousing is Chev or TH pattern 308.
  1. Another Toowoomba Sandman for sale HZ Valencia 308 4speed
    By Flamenco_not_Flamingo in forum Vehicles or Items Found for Sale
    Last Post: 12-07-2015, 09:44 AM
  2. Aussie 4speed shifter rebuild
    By r0bb0 in forum Driveline
    Last Post: 03-03-2015, 12:44 PM
  3. Saginaw box
    By Valencia in forum Driveline
    Last Post: 29-01-2014, 08:53 PM
  4. Replies: 3
    Last Post: 26-07-2010, 10:56 PM
