Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
Thread: Saginaw 4speed shifter??
    Cruiser RAEME's Avatar
    Bell housing is a Dellow multifit. Hurst Indy shifter, By the way how do you get reverse? The throw between 1 to 4 is short as. The stick barely moves. But for the life of me I can't find reverse? Cheers
    It looks like a Speco shifter mount.
    Sydney
    It will be to the left, beside first, but I've heard it can be beside second, depending on the shifter, or if the reverse linkage is installed wrong!
    The lock out will depend on the shifter, but usually is a lift up to engage.
    Yep Scottys right lift up and next to first gear
    i remember going to look at a PV for sale in Byford before i even had a drivers license. the old fella had swapped linkages on the 4speed so pattern was reversed.... this was supposed to be an 'anti theft device'
    Cruiser Dick61's Avatar
    Sep 2012
    Warragul, Vic
    I had the chance to buy an HG with a 350 and 4 speed back in the very early 80s, didn't get it because the gearbox was very noisy! Didn't know anything about M22 Rock crushers in those days, it was only $1600.00 cause the guy kept getting done for speeding.
    HQ Glacier White Belmont Ute
    Watch American Graffiti at the point where Harrison Ford drag races with the main characters in his rod. You can hear the M22 whining away on the movie.
    When replacing my worn out old shifter I let my young bloke (21) put in
    I said to him are you going to be right a to do it .do you want some tips, no no I'm right he said ,should have taken him about an hour .
    Came back an hour later he still had not quite finished,"I just got to put the linkages on" he said 2 1/2 hours later and lots of swearing &curseing I got under to show him how ...
    Neil & Cherone
    I walked away from a wb tonner that had a 350 and rock crusher coz the box was so loud i thought it was stuffed!
    I had a look this arv. Lifted and pushed, stuffed if I know still can't seem to get reverse. Also HK the gear stick mount has no brand markings on it but on the left hand side is US pat numbers. Not sure who made the mount tho. Cheers.
  1. Another Toowoomba Sandman for sale HZ Valencia 308 4speed
    By Flamenco_not_Flamingo in forum Vehicles or Items Found for Sale
    Last Post: 12-07-2015, 08:44 AM
  2. Aussie 4speed shifter rebuild
    By r0bb0 in forum Driveline
    Last Post: 03-03-2015, 12:44 PM
  3. Saginaw box
    By Valencia in forum Driveline
    Last Post: 29-01-2014, 08:53 PM
  4. Replies: 3
    Last Post: 26-07-2010, 09:56 PM
