Page 4 of 4 FirstFirst ... 234
Results 31 to 32 of 32
Thread: Saginaw 4speed shifter??
  1. #31
    Watch American Graffiti at the point where Harrison Ford drag races with the main characters in his rod. You can hear the M22 whining away on the movie.
    I walked away from a wb tonner that had a 350 and rock crusher coz the box was so loud i thought it was stuffed!
    Cruiser RAEME's Avatar
    Quote Originally Posted by panoz78 View Post
    If the gates on the shifter are not aligned properly you will not get reverse .
    To aline up use a tight fitting Allan key and put in the hole with the linkages of the box.
    Then put the arm on the box with out force them on .
    Spin the arm to the linkage to adjust
    Once all 3 are done remove the Allan key
    To get reverse you just push hard to the left then forward
    If then it doesn't go in spin one of the gearbox shafts a bit to line up the gears inside
    Attachment 11543
    Thanks mate. I'll have a go and let you know. Cheers
  1. Another Toowoomba Sandman for sale HZ Valencia 308 4speed
    By Flamenco_not_Flamingo in forum Vehicles or Items Found for Sale
    Last Post: 12-07-2015, 09:44 AM
  2. Aussie 4speed shifter rebuild
    By r0bb0 in forum Driveline
    Last Post: 03-03-2015, 12:44 PM
  3. Saginaw box
    By Valencia in forum Driveline
    Last Post: 29-01-2014, 08:53 PM
  4. Replies: 3
    Last Post: 26-07-2010, 10:56 PM
