Results 11 to 20 of 27
Thread: Quick Sandman ID guide reference sheet - Feedback needed
    Buggar that 77t. I thought I deleted that. I will get rid of it now.
    Just sent you a PV Absinth (the 77t is still there to)
    this is what order i deduct sandman ID or not - in order.
    this is quick way and there are always exeptions to the rule.
    as the thread title says - Quick ID guide
    1) XX7 or XU3 on Body tag & ADR chassis number must end in B for a start (to prevent tag swapping) - look further into this later. Brisbane cars only
    2) 2 seater
    3) built 10/1975 or later? GVM should be 1860kg / 1950kg / 2000 Kg
    4) Paint and trim codes are they sandman or not.
    5) if 9/1975 or earlier and non brisbane, they will always be grey areas to ID
    i think this should be the initial steps of the process......as it should ID 80% of genuine cars presented.
    tyre placards aren't really worth looking at because of all the repo ones around now. - unless you have had the car a long time.
    I think the troubles begin when you start trying to id an HJ. Particularly the early ones, unless you have books, original tyre placard you're left with wishing and hoping.
    However there is more investigation going on and hopefully we can continue to grow the knowledge here.
    Learner Driver Sandgirl's Avatar
    Is a hZ Sandman van
    In the section "is a HZ Sandman van" if it has a GVW of 2000kg after Dec 1977 as it was unique to HZ Sandman vans after this date.
    Hi Sandgirl,
    Will Amend, thankyou
    Quote Originally Posted by HZSandman View Post
    Hi Sandgirl,
    what about police divi vans?
    2000 kg but police blue paint code.
    P Plater sandman44's Avatar
    Chassis numbers
    Has anyone got any info on Chassis numbers and how they tie in with any other info on the vehicle eg. ID plates or HQ-HZ model number
    Quote Originally Posted by sandman44 View Post
    your chassis number should match the number on your ADR tag
    bunbury WA
    i noticed there is no 63v in the hz could be a sandman section why is that
    Quote Originally Posted by kaido17 View Post
    HZ Sandman trim codes
    Slate Black………………...18V…... Sandman only
    Chamois…….…………... . 60V….... Sandman only
    Sage Green …….…..…..… 33C….....Sandman only
    Tan………………………... 67V..........Base model and Sandman
    Light Grey………………. 11C….......Sandman only
    Light Blue……………….... 23C, 23V ..Base model and Sandman
    Jade …….…..…..………... 45V...........Base model and Sandman
    Buckskin………………...... 63V, 63C..Base model and Sandman
    Dk. Carmine…………..... 77C ….......Sandman only
    If you have an 8wm70 or 80 HZ with one of the trim codes in bold it is definately a Sandman
  1. mySandman Quick ID Guide
    By Blocker in forum HELP... Is This a Sandman?
    Last Post: 30-03-2023, 02:06 PM
  2. Replies: 3
    Last Post: 22-12-2013, 10:53 PM
  3. Sandman production build sheet
    By Absinth in forum Holden Sandman Q&A
    Last Post: 06-02-2012, 07:44 AM
  4. HX Owners Guide & Emission Guide on ebay.
    By hux454 in forum The Lounge
    Last Post: 13-04-2010, 07:34 PM
