Results 11 to 16 of 16
Thread: help needed - temp gauge sender.
    Rutherglen vic
    Some good info provided here. I also could use some help as I have a similar issue. I have a HQ & the temp indicator hardly moves also. I have tested the indicator with a decade box & is fine, it has a new thermostat fitted. So now I'm thinking the sender, after all the previous info provided by you all. Any chance of anyone knowing the P/n of the 74 HQ GTS temp sender. That way I can check if mine is correct. Thanks all.
    Quote Originally Posted by tim_138 View Post
    Thank you to everyone for your input. I found that VDO don't make part number 320.003 anymore, and apparently haven't done so since 2008. However, I was lucky enough to find an old stock one at Rare Spares. It had been there a looong time and the part number was correct even though it was labelled as a "temp warning light sender for XK -XC Falcon". I insisted on buying it even though the dude at RS insisted that it was wrong and was never going to work my gauge. Of course my temp gauge now works perfectly. Thanks to you guys for the correct info I needed to make an informed choice.
    l just bought a vdo 320.003 picked up today at repco they are still available to buy
    The VDO Part Number is 320.002
    for your 74 HQ GTS temp sender unit.
    Holden part number 7438478 for the sender unit and part number 7438477 for the adapter.
    Rutherglen vic
    Thanks heaps for that Innuendo, I will now get it sorted out finally.
    Mar 2012
    MELBOURNE
    Rare Spares Melbourne still has a stock of the 320.003 senders. They are listed as Ford suitable XR-XC, which explains the staff trying to advise on their application. However as VDO supplied parts to GMH & Ford it is possible they are compatible.
    Quote Originally Posted by gregbark View Post
    It's not a matter of compatibility. VDO 320.003 is 100% correct for both Holden, Ford and many other makes (in the appropriate year models). The fact your staff can't do more than read a sticker/label doesn't build customer confidence. VDO still stock and supply all numbers listed in their catalog.
  1. Temp Sender
    By hxbunny in forum Engine
    Last Post: 08-12-2014, 07:45 PM
  2. Autometer temp gauge
    By jaft in forum Electrical
    Last Post: 18-05-2014, 10:09 PM
  3. what temp did you get to.
    By buck in forum The Lounge
    Last Post: 12-01-2013, 09:44 PM
  4. oil gauge sender
    Last Post: 10-08-2012, 11:31 PM
  5. HQ GTS Temp Gauge
    By GNW1974 in forum Electrical
    Last Post: 24-11-2011, 10:21 PM
