Results 1 to 6 of 6
Thread: rear window in panel van
    I am closing in the rear window on the Hj panel van, and reinstalling the support rib which was removed, I notice it should have 3 supports either side, but it looks like hx and hz only had one either side in the middle, is that correct
    They get removed when windows added.
    do you know if the support rib on the hj is the same as hx and hz
    Administrator HZSM50's Avatar
    Bonner ACT
    G,day archy,
    no its not correct both my HZ's have three each side.
    Quote Originally Posted by archy View Post
    Yep, and Hq and WB too.
    They are all the same from HQ to WB.
  1. Complete windowless side panel cut outs to replace window panel
    By HX Bordeaux Met Sandman in forum The Lounge
    Last Post: 07-04-2013, 07:49 AM
  2. Rear window blackout
    By Grunt in forum HX Sandman
    Last Post: 03-01-2013, 12:21 AM
  3. Wanted WB panel van rear window
    By looznu in forum Archive
    Last Post: 30-03-2011, 10:57 PM
  4. rear bubble window
    By spuncog in forum Paint & Panel
    Last Post: 21-12-2010, 10:27 PM
  5. Factory tinted rear window for ute!
    By stickthis in forum Archive
    Last Post: 10-07-2010, 12:24 AM
