Page 1 of 7 123 ... LastLast
Results 1 to 10 of 64
Thread: HX Sandman Aquarius
    Aug 2010
    HX Sandman Aquarius
    hi guys
    i would really like your help, i have recently purchased a hx panelvan, and i would really like to know if is a sandman as it doesnt have the original paint on it anymore. i would like to know what these codes indicate. here are the numbers and codes.
    Tyre Placard: 9942992
    Model: HX8WM70
    Body: 220824-A
    Trim: 1914-60A
    Paint: 568-17778
    Eng: L32
    Trans: M20
    Diff: GV7
    1950 GVW
    20141A
    Seat Cap: 2
    thanks Ben
    Welcome Ben
    I have copied this for you from the Sandman ID guide for HX on the website
    So a true HX Sandman will have the following features:
    GTS components which include GTS dash, console shift, rally rims and bucket seats;
    Full length headlining (includes a welded metal headlining strip above the tailgate door);
    Trim code of 18V, 60A, 65A, 67V ;
    8WM70 (van) or 8WM80 (ute) on body identification Plate; and
    Seating capacity of “2” on ADR plate.
    Others will verify this, but you have 60A trim code and 8WM70 and seating capacity of 2
    Also this is the tyre placard for a HX Sandman
    4.2L XX7 or XU4 Panel Van 10cwt 9942992
    which means you pretty much have a Sandman
    Absinth, or someone with more knowledge can you confirm this for Ben?
    Welcome Ben
    100% sandman. 60A on a holden bace model is 100% sandman.
    Aug 2010
    Thanks guys, greatly appreciated. Great news. not bad for $700.
    So What does these numbers mean then:
    Trim: 1914-60A
    Paint: 568-17778
    Thanks Heaps.
    ID codes
    Quote Originally Posted by 76hxpano View Post
    Trim: 1914-60A
    Paint: 568-17778
    Thanks Heaps.
    Have you got some pics Ben? would love to see them, and some interior as well.....sounds like a bargain at that
    Aquarius 17778 - 1914 paint code, and Decal which would have been on this van is DX5
    60A is trimcode which is chamois and black vinyl
    568 is a mystery but it is also on our Van somebody else maybe able to help with what that number means....
    Trim: 1914-60A
    Paint: 568-17778
    Thanks Heaps.
    1914 is Holdens exterior trim code for Aquarius colour.
    568 is the Dulon code for solid colour.... IE not metallic.
    60A is Chamois trim and was available in all HX commercials so does not in itself confirm Sandman status....
    The plate info basically is correct for a Sandman but you need to check it has courtesy light switches in the door jambs, full headlining etc.....
    HX are a bugger to identify, as things that helped in HQ and HJ don't necessarily help in HX.
    Your best identifiers will be the full length headlining attachment bits and an N66 wheel winch. Unfortunately a console and courtesy light switches don't help that much in HX as they were available on base model, but the headlining was extremely unlikely on a non-Sandman base model. Having a 1950kg GVW helps heaps too. I'd be 97% confident it is a Sandman.
    Aug 2010
    Ok then, maybe a silly question but what is the N66 Wheel Winch?
    Leadfoot abncraig's Avatar
    Ravenswood WA
    my guess would be the spare wheel winch there is a thread on here about them maybe someone can shortcut it for you. not absolutley sure what a n66 is though
    N66 is the option code for GTS rims, and the winch is different. GTS rims were standard fitment to most Sandmans (late HZ got alloy N67 also used on HZ SL/E and WB), and as such it is a telltale in identifying.
There are currently 36 users browsing this thread. (0 members and 36 guests)
  1. My HX Aquarius 308 4 Speed Sandman
    By Matts HX in forum HX Sandman
    Last Post: 11-11-2014, 02:31 PM
  2. HJ Sandman in Aquarius
    By L31 Sandman in forum Holden Sandman Q&A
    Last Post: 15-09-2014, 07:48 AM
  3. HX Acacia Ridge Sandman ute, Aquarius, slate black, L34 M41 3.08:1
    Last Post: 19-11-2012, 09:30 PM
  4. Hx sandman aquarius stripe color
    By JONESY in forum HX Sandman
    Last Post: 15-06-2012, 09:04 PM
  5. Hx sandman in Aquarius
    By lockyhxpvan in forum The Lounge
    Last Post: 20-11-2011, 12:47 AM
