Results 1 to 5 of 5
Thread: PCV Valve air breather filter
    Leadfoot Spike's Avatar
    Oct 2014
    Have just noticed this item for sale on ebay. it looks like it is a filter that goes inside the air cleaner and plugs directly into the hose from the pcvv. 2 questions I guess. 1. is it necessary for proper running? and 2 would it be required by the vehicle inspection Nazis for rego [ in WA ]
    Knowing the Nazis over here Spike my guess is it would have to be connected
    Oct 2014
    yeah your not wrong, repco tomorrow morning for me
    Try Veales Spike there way cheaper than Ripco
    i always suggest you try your luck. i've had an amazing run and never failed a first inspection. don't give them a reason to fail you.
    seat belts
    tyres
    bushes
    lights
    play in steering rack/box
    heater
    fan
    wiper and washer
    no holes in seats (just put covers on)
    exhaust (absolutely no leaks anywhere)
    check for fray in front brake hoses
    oil leaks - just pressure wash till you think you've blown through the block (that will mean its clean enough)
    they might want all locks to work (does your tailgate lock?)
    front and rear indicator and brake light lenses not faded out
    charcoal canister hooked up?
    etc etc
