Page 1 of 8 123 ... LastLast
Results 1 to 10 of 76
Thread: electrical help - fan, horn, blinkers, temp
    some advice tips help please
    WB tonner
    just dropped a 253 and trimatic in - was 6cyl manual. I have used a complete wb column trimatic wiring harness for conversion too.
    blinkers and horn were working until I put GTS wheel on and/or new neutral safety switch. Tried a regular steering wheel again - no change. changed direction indicator switch/horn contact switch as horn contact was worn - no change. When I press horn pad I can hear the relay clicking but no horn noise.
    heater fan and temp gauge are not working. Fan did not work pre conversion. I've tried other senders and gauge. I've also tried two other fan switches. Temp wire from harness jumps around all over the place from 1.3V to 9.5V with ignition on (don't know if this is abnormal).
    have checked all fuses visually and all (except brake lights - bottom left two) seem to have 12V with ignition on.
    i have a multi-mete but that's about were my tooling and skills end!
    any suggestions would be appreciated
    Leadfoot Spike's Avatar
    Oct 2014
    Vom, if you have changed 2 things [s/wheel and neutral sw] and put 1 back to as it was [ s/wheel ] maybe go back and check the neutral sw or put the old 1 back in. or maybe you have accidently disconnected something.....maybe
    Something is loose or making a bad connection. Check EVERYTHING! Auto electrics never fail to amaze me with their quirks.
    safety switch was minced- it would start in any gear and rev lights would not work. new one works nicely but i think i reversed the purple plug from memory. this may have something to do with it but I will need to check the old mans original WB to be sure. anyways safety switch and rev lights are working perfectly now but were not prior
    seems my post was absolutely shredded by far more interesting posts so, as they say in the internet realms... bump
    Administrator HZSM50's Avatar
    Bonner ACT
    Hard to pinpoint the problems in an electrical system without being there,
    all I can offer is something has come a drift. my suggestion would trace all the wiring you have changed,
    and double check every connection.
    Sorry I cant be of more help
    If the horn relay is clicking when the pad is pressed, it means that the relay is getting the earth from the horn pad. Therefore you MAY have a horn issue OR where it mounts to the nosecone.
    Common issue for fan not working is the earth wire going to the fan body is loose.
    With the gauge, you may get that variance in voltage because of the pulses from the voltage stabaliser. Not sure now but I think if you earth the temp wire with a test light, the gauge will read hot.
    Lastly, is the column a WB one (with hazard switch) or HX/HZ one?
    thanks heaps agro.
    yes, WB column with hazard button (although it is temperamental and doesn't like to stick on without some convincing)
    I'll clean earth on nosecone or maybe shift earth as the battery is also earthed to nose cone and i'm not exactly having a win at the moment.
    NOTE: I put a fat ass +VE battery to starter cable on and the indicators started working again. I'm in the throws of making a -VE which is obviously even more critical. I'm hopeful for some miracles
    I think the starter could be earthed better too - anyone have any tips or tricks with this? It's a smaller cheap as chinese type starter
    Glad to help mate.
    Best thing to do is to put a decent earth straight to the stater mounting bolt, then a good one (not as big of course) straight to the nosecone. This will earth all lights and gauges.
    You're getting there....
