Originally Posted by
wbute
There is no "earth" at coil for the instruments???? Are you sure that's an earth wire on the diagram and not the wire for the tacho on sports instruments?
I think you are confused as to what an earth is and does?
Earth wires are generally always the same colour in a harness, they all go to "earth" which will be a metal object that is in some way connected back to the neg battery terminal.
I still recommend a test light. I can't work on anything that's 12V without one.
I still don't know what's not working? If the handbrake light doesn't come on then it will most likely be the switch in the lever, not a wiring problem. Gauges not working is often the sender, unless they are all not working then you check in the dash wiring.
I think you could have issues with using a red motor in a WB as well. They are not up to the emissions level of WB.
