Page 8 of 8 FirstFirst ... 678
Results 71 to 76 of 76
Thread: electrical help - fan, horn, blinkers, temp
  1. #71
    Got there... but it took too long
    Washer - Corroded terminal and pump stuffed
    Horn - can hear relay clicking when horn depressed - Horn replaced
    Reverse lights - this was bullshit! The slop in the shifter is causing havoc with the rev light switch
    Heater fan - had no idea WB had a fan relay. Fuse/relay was blown/melted
    temp gauge - sender stuffed
    oil switch - switch was stuffed
    handbrake warning on dash- dummy light cluster was stuffed - very tricky considering some of the lights on the cluster worked
    so I'd convinced myself that 7-8 items that were stuffed had to have a common link. i was wrong. it's was just your typical neglected bucket of shit work ute!
    i've learnt a heap and have no regrets as i can only dream I would've paid a auto sparky telephone numbers to fix them all. thanks to all that gave me pointers!
    Fantastic! I told you you'd get it. You now have so much knowledge about YOUR electrical system.
    Experience like this will help you so much in the future.
  3. #73
    Good. Electrics are fun....
    It's always a bonus when you work stuff out that's for sure.
  4. #74
    Great work. Did you end up using a test light to do this?
    Don't tell WB but no, I didn't use a test light.
    All good mate. You can do it anyway you like. You got the result. Plus you are an expert on voltages now.
