Great work WB. Inspiring me to dig out the ute and make a start. There is a guy on Facebook that can modify your loom to suit 5Lt EFI. If i find it i will post it up.
James, what computer are you going to use and is it manual or auto.? I used a Gregory's E.F.I manual I think its volume 4, has very easy to follow wiring diagrams for Holden V8s and step by step test instructions for all the circuits including voltage range, fault codes and drive motors ect. Studding the ECM wiring circuits and system operation diagrams it quickly makes sense. If your going to use the original harness and computer there is only around four wires you need to connect to get them to run. I know when you look at the harness it looks very daunting, but its not that difficult with only a basic understanding of wiring and electrical relays. Some auto electricians charge $500-600 just to do very simple joining of a few wires and put a fuse and relay into the circuit. And when you complete the wiring it will give you the confidence to maintain it well after the rebuild of the car is complete. Its a learning curve well worth taking in my opinion.
I have done all my own auto electrics on the farm pretty much since I wired my first set of driving lights in when I was 21. I have a fair grasp on basics, but it’s like everything, the first time doing something like a EFI conversion is daunting. I reckon it is pretty straight forward but as you say, it looks complicated.
It is the 4LE auto and I will use the standard VT computer.
I will try and track that Gregory’s book down.
I got a heap of info from Byron, and he reckoned I could get the cruise control to work as well, using a WB Stato steering column but I will be happy just to get it going reliably to start with.
I have the best wife! Look what turned up under the Christmas tree!
Cool, so its going to be a cab off chassis rebuild then.
Its the only way to do the job right cant wait to put my van on one hopefully in the next month or two
There are currently 47 users browsing this thread. (0 members and 47 guests)
