Hey HZSanFan, if you end up getting this part made, I could sell one for you.
Hi HzSanfan
Iam having the same issue as you as I have the cap [ left in photo ] the plate for the cap [ top centre of photo ] but not the star piece.Even with that Iam not sure how it would fit to steering wheel.If you are getting that piece printed I would certainly be interested in buying one from you. Thank you DALE
G'day Dale
The "star piece" has two holes on the outer edge, that line up with any 2 of the 6 holes on the alloy horn contact plate. (The part that mounts with the 4 bolts & springs to the steering wheel centre)
Just need to find a couple small screws with the same thread as the Allen key bolts from the earlier horn cap.
Hope that makes sense!
Max
Thanks Max that makes perfect sense.All I need now is to find that star piece as I am missing it.
Dale
I have spoken to a guy that is prepared to 3D print the nylon attaching ring but he needs all the correct dimensions to enable him to design the part for the printer.. I only have half of the ring and would only be guessing if I gave them to him. Would anybody be able to help with these measurements of the pictured ring? TIA, cheers Kym
HZ Persian Sand Mk2 Sandman (under full restoration)
HX Chamois Monaro GTS
Im guessing you didnt do any good with the eBay one?
I think I have come up with one of these, that I could borrow, but he wouldn't allow me send it to you for copying.
I might be able to check out getting it copied. Any idea how much your contact was going to charge to 3D print it?, so I know if I can get a good price.
Also, not knowing much (anything) about 3D printing, is there a scale or degree of accuracy printer needed?
Max
If you can get a copy made I would certainly be up for one as well.
Thanks Dale
Just the dimensions would be great Max, I can then have a drawing done to send to him, I have the half piece to get the finer measurements of the groove around the outer circle, Cheers, Kym
No problems Dale, I'll let you know, Cheers mate, Kym
There are currently 21 users browsing this thread. (0 members and 21 guests)
