Page 5 of 5 FirstFirst ... 345
Results 41 to 49 of 49
Thread: VDO oil pressure sender
  1. #41
    I reckon you need to get the gauge repaired. The resistor test shows that it's not reading correctly.
  2. #42
    P Plater HXsman's Avatar
    Jul 2016
    Hi All,
    I ran the test again. I think Ill try the multimeter test and replace the wire in the engine bay.
    Totally appreciate all of your help so far.
  3. #43
    i'd take the one on the left every day
    HXsman
    How did you go with your problem ? Have you sorted it out yet ?
    Neil & Cherone
  5. #45
    Jul 2016
    Hey Panoz,
    In the end I gave up, at the moment it runs just above the red on the highway but at idle the needle is essentially not doing anything. Short of trying my oil pick up and pump I'm not sure what to do?.
    Tried the resistor test.
    Tried a new four gauge cluster
    Tried 4 different sending unit
    Replace wiring.
    Any thoughts ?
    Dean 0400 182 434
  6. #46
    I would go and buy an after market oil pressure guage and test it just tape it to the windscreen wiper and go for a drive I reckon earthing could be an issue but you need to know the actual oil pressure
  7. #47
    Jul 2016
    Thanks Beachy,
    I have thought about that too, will give it a try one day. I've moved onto other problems but will come back to this one
  8. #48
    It's got bad oil pressure and the gauge is correct???
  9. #49
    Mar 2012
    MELBOURNE
    If you ring VDO and ask for Graham Tilley he might be able to advise. Roger Howard at Howard Instruments could also advise.
  1. Electric Choke - Oil Pressure Gauge
    By rallyvan in forum Engine
    Last Post: 30-03-2015, 11:42 PM
  2. Temp Sender
    By hxbunny in forum Engine
    Last Post: 08-12-2014, 06:45 PM
  3. no oil pressure
    Last Post: 05-01-2014, 06:47 PM
  4. Hx fuel sender into 8/74 hq
    By Vombil in forum Engine
    Last Post: 28-02-2013, 01:21 AM
  5. oil gauge sender
    Last Post: 10-08-2012, 11:31 PM
